Green Foam in Differential
Old Aug 23, 2001 | 11:48 PM
GTA88's Avatar
Seriously. I just checked the diff today for the first time ever. It hadn't been leaking and it's so awkward to get to without a hydraulic jack, etc, etc... just lazy. Anyway, when I put my little finger in all I could find was thick green slimy foam. I know I have the LSD (posi) since I have the G80 RPO code. Is this green foam normal, and if I want to add some fluid, what should I add ? My fbird owners manual says to only add part number 1050010 if I have rear disc brakes. btw I used to get a clicking sound from the rear area in general, at slow speeds, but it has gone away by itself.
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Aug 24, 2001 | 08:49 AM
GTA88's Avatar
Nevermind. The dealer said green is the right color, and the that foam is normal.
Old Aug 24, 2001 | 09:01 PM
JETHROIROC's Avatar
Mine is never foamy or green in three vehicles when I check or change the rear lube. Sounds like some sort of water or additive contamination to me. I would drain that SOB now and put in some Mobil 1 75W-90. Just my $0.02.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
dbrochard
Jan 28, 2016 08:42 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
