10 bolt specs
Old Aug 25, 2001 | 09:57 PM
Joe89Bird's Avatar
10 bolt specs
I'm looking around to find out the specs for my 10 bolt drum brake rear end. does it have 26 or 28 spline axles, and are they different from drum to disc brakes? what needs to be changed to change from a drum to disc? thanks
Old Aug 25, 2001 | 10:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Search through the archive.
Your 89 should still have 26 spline axles. It was a changeover year so the only way to know for sure is to pull an axle. 28 spline axles didn't become standard until 90.
Changing from drum to disk requires more than just a simple swap. The discussion has been brought up many times and it's best to just search through the archives.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jorlain
Oct 8, 2015 01:57 AM
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
