need help with dakota box on t56
Old May 16, 2009 | 08:15 AM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
anyone want to share how the hooked there dakoata box up power and ground is easy i have a 91 camaro so i have the yellow to the output but not sure where to connect ground and how to connect t56 speed sensor and help??
thanks
Old May 16, 2009 | 11:49 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: need help with dakota box on t56
I just did this but with an A4 and using a TCI transmission controller.
If I had your system I would first try it this way using application #2 in the directions. The yellow wire from the VSS would go to Speed Input Signal. I would put the Purple Wire from the VSS to ground.
I would take the yellow wire from the ECM(B10 in my case) and put it in out 2. I would take the purple wire from the ECM(B9 in my case) and put it in sensor ground.
camaro1185
Oct 26, 2015 06:51 AM
topteam54
Oct 6, 2015 12:21 AM
el_muerte
Sep 16, 2015 12:01 AM
mygta87
Sep 14, 2015 10:36 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
