Tranny seal help needed ASAP!!
Old Aug 29, 2001 | 04:13 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Tranny is leaking in between front of tranny/back of torque converter...wondering what seal we need
This is for a friend...reply here or email at
Irocpunk@aol.com
THANKS!!!
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Aug 29, 2001 | 05:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's called the front pump seal... it's a pretty ordinary type of metal-clad lip seal, probably $10 or so
ICON Motorsports
Old Aug 29, 2001 | 05:54 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It may or may not come w/ a new seal retainer. It goes over the seal once installed and has "fingers" that dig into the outside of teh pump to help prevent the seal from walking out. Also, once the torque converter is out and take a good look at the bushing. If the bushing is shot and the torque converter is allowed to move some, the new seal will do you no good.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Aug 29, 2001 | 10:09 PM
fly89gta's Avatar
Car: 2018 Camaro SS
my friend also wants to know if he can use high-temp RTV0
Old Aug 29, 2001 | 10:29 PM
Crosley4's Avatar
It's also possible that the converter hub bushing has "walked" out to the lip of the seal and caused the seal to start leaking. You don't mention the year, make of the trans or I did not see that info.
If that's what has happened, then you have more things to fix.
Old Aug 29, 2001 | 10:31 PM
fly89gta's Avatar
Car: 2018 Camaro SS
89 GTA 700r4
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
