Retrofit Help, PBR Disc to drums
Old Aug 30, 2001 | 11:51 AM
UVA3rdGen's Avatar
I have ruled out rebuilding my brothers 9-bolt and decided to go find a 10 bolt. All the 10 bolts with disc were impossible to find or way to expensive. I do not want to convert to a 4th gen because of spacing issues so I decided to find any old 10 bolt with drums and just beef up the internals for the same cost of buying a rear with disc. Will I notice any differance in stoping power? Those drums look pretty beefy and there really is not that much weight in the back of our cars anyway. Did they make different size drums? Any drums I want to stay away from? Thanks in advance. PS anyone got a beefed up rear end they would let go for around 600?
Old Aug 30, 2001 | 01:00 PM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
I don't have a rear that'll work for ya ( I do got a '90 10 bolt 2.73 with aluminum drums but nobody else wants it so why would you) but I want your brother's PBR 9-bolt setup!!! Do I win the auction??? At the very least I need the backing plates that mount the PBR's. Thanks!!! Send me a note or get ready to get one from me...
'89 Formula - Thunderchicken - 355 Vette L98/T-56/3.70 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old Aug 30, 2001 | 01:05 PM
UVA3rdGen's Avatar
Want to even trade? The ring gear is missing 3 teeth, but other then that it is solid. What kind of shape is the rear in?
Old Aug 30, 2001 | 01:15 PM
Car: '89 Formula
Engine: 355 TPI
It was fine for 90K miles - hey for what it mattered the posi even worked - when I took it out to trade it for the 3.27 9 bolt with the old gm disks - I want to put the PBR's on the thing because at the end of it all, GM rear disks SUCK.
I really didn't want any money for it and I don't know why you'd want it myself... 2.73's SUCK too.
Old Aug 30, 2001 | 04:46 PM
UVA3rdGen's Avatar
I am totally serious, if it has 28 spline axels and the drums work well it will be fine. I would upgrade to a street locker, one of those pressure cap covers and 3.4 aftermarket gears and it would be a hell of a lot stronger then a stock 9-bolt
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
