flywheel size?
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
flywheel size?
I have a 700-r4 mated to a GM 350. Can anyone tell me how many teeth are on my flywheel? I will be replacing the starter and the manufacturer needs to know. Thanks guys,
John
Mods: 14" K&N open element, 180* stat, ram-air hood, Accel cap & rotor, MSD Super Conductor Wires, 24mm solid rear & 36mm hollow front sway bar w/ PST polygraphite bushings & endlinks, Spohn SFCs, WS6 springs, SLP 1 3/4" Jet-hot coated headers, Hooker 3" cat-back, Catco high-flow cat, Comp Cams High Energy 268 cam, AFR 190 heads, Weiand Action+ intake, Comp Pro Magnum 1.6:1 Steel Roller Rockers.
http://www.homepagez.com/350thirdgen/
John
- 84 Firebird w/ T/A gfx
- 350 4bbl (LM1)
- Automatic
- Non-leaking T-Tops (new rubber all around)
- Working headlights (new parts)
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
153 teeth.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Thanks, I'm a transmission retard. I knew it was either 153 or 168. What kind of cars did they use a 168 on?
John
John
Car: 87 GTA
Engine: 355 Chevy
i think it was the older 2-pc rear main cars that had the 168.
1987 GTA 355, carbureted, TFS heads(non G2), 6-speed, McLeod clutch, 11.3:1, dual 3" flowmaster 2-chamber exhaust with NO tailpipes, 98 z-28 wheels, soon to be replacing weak 10 bolt with 12-bolt...gettin tired of breakin axles....
...Whatever turns your tires.....
hmmm... My motor is a 2pc rear main seal. It is made as a replacement for 69-85 GM vehicles. Does this change things? Thanks guys, I know this is an old topic, but I need the right starter. (still havent ordered it)
John
[This message has been edited by johns84bird (edited August 28, 2001).]
John
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
i used a flywheel from a 80 g-body with a turbo 350 trans, 2 piece seal, my 700 and f-body starter bolted up just fine.
79 Chevy Malibu Cpe
305 TPI/700-R4,3:50 Posi 9 inch,
Custom Turbocharged,
ported upper and lower intake,
214,224 duration .450I .465E lift
749ECM, modified SyTy software
Website:
www.turbotpi.homestead.com/SATURN5.html
79 Chevy Malibu Cpe
Website:
Pac J
May 17, 2020 10:44 AM
Stangski09
Nov 14, 2015 01:27 PM
el_muerte
Sep 16, 2015 12:01 AM
