how to tighten bands in a 700r4
Car: IROC Z28
Engine: 5 litre 305
any one know whow to tighten the bands in a 700r4 tranny, that is if you can, as my box slipps when warm, i am having a new one built but in the mean time i thought i may be able to make it last a little longer
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: how to tighten bands in a 700r4
Nice idea, but the design of the 700R-4 doesn't allow any such. Your best hope is clean fluid and fresh filter, then keep your foot out of the go-pedal.
Car: IROC Z28
Engine: 5 litre 305
i thought as much, cheers for the info, been out for a spin tonight and the trannys major porly just hope the new ones here soon
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There is no external band adjustment on a 700R4. Pressure on the band is supplied by the servo piston. The adjustment is changing the length of the shaft on the servo piston.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
That doesn't work because then the 2/4 band drags on the drum all the time.
no green
Jan 9, 2016 09:22 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
24, 4l60e, 700r, 700r4, adjust, adjustment, ajustments, band, bands, fluid, length, release, servo, tighten, transmission
