Gear sizes?
Old Aug 31, 2001 | 11:29 AM
custman87T/A's Avatar
Gear sizes?
I have a set of 3.73 gears from my rear when I had the pinion bearing done they also changed the gears to a much more friendly 3.42.
My 3.73 gears are much thicker than a friend has for his gear swap on his T/A.
My question is it it a carrier difference on why the gears are a different thickness?
If so which carrier is thicker in the ring gear a 2-series or 3?
87 Black on Black T/A
T-Tops Digital dash
5.0 TPI S/R Torquer 305 heads Summit TPI cam
204/214 @.050 .420/.442
SLP headers and catback
A4 with 3.42 gears
Fully loaded and everything usually works.
Old Aug 31, 2001 | 12:59 PM
82camaro's Avatar
Car: 82 camaro SC
Of the same ratio gears; The 2 series ring gear is thicker than the 3 series.
3.73's to 3.42's made a big difference?
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Aug 31, 2001 | 01:23 PM
around town...no they feel very similar but on the highway it feels much better especially 70+mph.
and thanks for answering my question...
T-Tops Digital dash
A4 with 3.42 gears
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
