Odd thing happened last evening, the tranny did not
Old May 18, 2009 | 05:30 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
want to go into Park. When I pull the car into the garage, and came to a stop, I had a lot of resistance to putting the gear shifter into Park from Drive in my 700R4. What would cause this?
Old May 18, 2009 | 05:35 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Odd thing happened last evening, the tranny did not
Something could be in your center console blocking the shifter. Cable could be kinked. But I don't see how that could happen all of a sudden unless you did some work on the car around that area.
Old May 18, 2009 | 05:46 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
I did not work in that area for a long time. I dont remember how to look into this matter from the top side. How do I remove the console from inside the car? I should also look under the car.
Ghettobird52
Jul 5, 2024 11:18 PM
Bob88GTA
Aug 18, 2015 03:31 PM
BurlyChev
Aug 16, 2015 09:08 PM
hokis
Aug 9, 2015 03:57 PM
