700R4 Good or Bad?
Old May 20, 2009 | 08:19 PM
Chaos2084's Avatar
700R4 Good or Bad?
I am getting a new Camaro 84 Sport Coupe with a 305 auto which has the 700R4 in it. Buying it to replace my 85 Z28 thats trashed I have a 350 in my 85 that I am going to swap into the 84. My question is how well will the 700R4 hold up to the 350? It's not built or anything not sure of the horsepower just have exhaust headers to 3" exhaust back to duals a Edelbrock intake and a Holley 4 barrel 600CFM Street Avenger. This will be a sort of Daily driver.
Old May 20, 2009 | 08:24 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: 700R4 Good or Bad?
Should not have any problems at all My Son's '92 has a 325hp L98 the 700 works fine. HOWEVER make sure the TV cable is adjusted correctly! If their is a weak spot in the 700 it is the 3-4 clutch pack.
Old May 20, 2009 | 08:36 PM
Chaos2084's Avatar
Ok thank you for the quick reply.
Here is a link to the ad not a bad looking car for being 25 years old.
http://portland.craigslist.org/nco/cto/1179555772.html
Old May 20, 2009 | 09:27 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
There not a bad transmission. just make sure you give it a regular maintance like change filter and transmission oil every other engine oil change. might be a little much but i do that and works like a charm. but i am going to T-5 soon but 700r4 is good just be nice to it.
Old May 21, 2009 | 12:18 AM
Chaos2084's Avatar
I have the T-5 in my 85 it held up to it really well ever since I got it the tranny was going out and I was hard on it. Finally went still driveable but when I try to spin them just gets stuck no clutch pressure or anything. And with the 300,xxx some miles on it. Fourth gear went out and so did third.
But for $200 for the whole car that's a steal it's in a 1,000 times better shape then mine is in.
camaro11j
Sep 19, 2018 08:49 AM
86IROC112
Apr 9, 2016 10:20 PM
Reddeath210
Oct 6, 2015 08:20 AM
TreDeClaw
Aug 14, 2015 06:58 PM
fonzie85
Aug 13, 2015 11:50 AM
