9 bolt axle install, need help
Old May 21, 2009 | 09:31 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Swapped from an 87 GTA 10-bolt drum to an 89 9-bolt disc.
I got the axle in but what gear oil is recommended for 9 bolts?
What do I need to get the emergancy brake lines connected and working properly?
Do I need a longer cable from front to back on the left side?
Old May 22, 2009 | 06:10 PM
big gear head's Avatar
Re: 9 bolt axle install, need help
Use 80W90 gear oil and a bottle of Ford limited slip oil additive. You can use the GM additive, but you might need 2 bottles to get it to stop popping when you turn a sharp corner.
hectre13
Dec 11, 2023 08:14 AM
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
red90IROCls1
Aug 25, 2015 06:56 AM
