Another rear end swap question(s)
Old Sep 1, 2001 | 10:49 AM
3504mula's Avatar
Car: 90 Formula
I have been trying to search for an old post about this but could never find what I was looking for. First of all, I now have a 3:08 open drum rear end. I hate it and I spin everywhere I go. I have the oppurtunity to buy one of two rear ends. The first one being a 3.42 posi drum rear out of a 1986 or 87 Z28 (aftermarket gears that have a slight wine and it also has high perf. brakes). The other is an 86 TA disk w/ 3.73. They are both pretty much the same price but I have to buy brakes for the disk one. My question is which one is best for me? I would like disk brakes but I am not sure if it is worth the work and money to convert it. But which gear is better. And finally if I buy either one of these will it be a direct swap other than disk brakes?
1990 Formula 350
Hooker Headers, Random Technology Exhaust w/ no cat, K&N, Airfoil, AFPR, MSD 6A Ignition, Performance Resource chip, Metco LCA's w/ brackets, F Body Perf. Panhard Rod and Strut Tower Brace, A 3.08, open, drum rear end installed by previous owner (good choice), 1999 Formula Wheels, White Face Guage Overlays
Old Sep 3, 2001 | 10:17 AM
3504mula's Avatar
Car: 90 Formula
Old Sep 3, 2001 | 02:29 PM
MichaelRBrumm's Avatar
Do you realize that you will be trading your '90 28 splines for (pre-88) 26 splines? Kinda the wrong way to go...
Also, you haven't really described what you plan to do with the car... street? drag? racing?
Old Sep 3, 2001 | 02:41 PM
82camaro's Avatar
Car: 82 camaro SC
splines aren't going to make much if any difference. However, I would still go with what you already have. Richmond 3.73's, slp torsen or powertrax locker, new bearings--you end with a very solid rear-end that you know will last, rather than buying a used one may have problems early down the road. Worn posi come to mind.
If you can live with your current gears a powertrax is a quick install(the gears won't get removed) and you will end up with more traction than any limited slip(posi).
PS I started out with your exact problem.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 3, 2001 | 02:59 PM
3504mula's Avatar
Car: 90 Formula
I don't believe this rear end is stock. I thought all ws6 cars in 1990 came with posi disk rears. Maybe not. But if it is not stock then I don't know what number spline I have. How do I find out more about the rear end in my car? If I do go with a locker, what gears do you suggest? I use this as a daily driver/raced on the weekend. Gas mileage does not matter.
Thanks again
1990 Formula 350
Hooker Headers, Random Technology Exhaust w/ no cat, K&N, Airfoil, AFPR, MSD 6A Ignition, Performance Resource chip, Metco LCA's w/ brackets, F Body Perf. Panhard Rod and Strut Tower Brace, KYB AGX shocks in the rear, A 3.08, open, drum rear end installed by previous owner (good choice), 1999 Formula Wheels, White Face Guage Overlays
Old Sep 3, 2001 | 04:45 PM
Z28DJP1987's Avatar
.02 cents worth of advice...Keep Searching.
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
