R4 trans wont shift into OD at WOT
Old Sep 3, 2001 | 12:24 AM
MouseCamaro305's Avatar
l know this is the stupid way that GM designed their transmissions, but is there anyway around this thats free, or atleast fairly inexpensive thats doesnt require chip burning?
thanks in advance
Old Sep 3, 2001 | 12:54 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
B&M has a nice little part that cures this. #70237 and is $34 from Jegs. The car I have had it and a 2200 stall Corvette convertor installed in the early 90's. But with the 2.77 rear end, I've never had the room to test it out.
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Sep 3, 2001 | 05:42 AM
transfixleo's Avatar
That part (the Throttle Plunger) doesn't always do what people want. The correct part is the Police package 3-4 TV Valve Assy. If you find a good Chevy dealer they should be able to come up with a number for you. No it isn't free though.
Old Sep 3, 2001 | 05:17 PM
86_Dan_Z28's Avatar
Car: 86 Z28
The GM part no. is 8673948. If you do install this part you will have to recalibrate the governor and the 3-4 shift timing spring because it will go into overdrive to early and bog down the motor.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
