Total width of rear ends...89, 95 ? will it fit?
Old Sep 4, 2001 | 05:08 PM
MM89Iroc's Avatar
Does anyone know the difference in the widths of the 89 rear(with drums) and a 95 rear (with disc) both out of camaros. I am looking to upgrade my 2.73 open rear to a posi 3.42 and I found a 95 rear that might work if it isn't different.
Also will my rims fit the bolt pattern and backspacing correctly on the 95 rear? My car is an 89 Iroc while the rear is out of a 95 Z28.
Old Sep 4, 2001 | 06:28 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
The rear end out of the '95 (4th gen) is approximately 3-4 inches wider than the '89 (3rd gen). The bolt pattern is the same for the wheels. If you get wheels off of a 4th gen F-Body, they will fit perfectly on your car without sticking out.
1991 Z28 - 350 TPI, T56, McLeod street clutch, LT4 pressure plate, Pro 5.0 shifter, ported plenum & runners, AFPR, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
Reddeath210
Oct 6, 2015 08:20 AM
