T-5 to T-56
Old Sep 6, 2001 | 04:10 PM
Chris90Formula's Avatar
T-5 to T-56
When swapping from a T-5 to an OEM T-56:
Do you need to make the hole for the shifter larger?
Can you reuse the master cylinder from the T-5?
thanks,
Chris
1990 Formula WS6 - 305 - T5
14.3 @ 96.5 mph
MSD 6AL
Strut tower brace
Subframe connectors
MAC headers
Underpulleys
Old Sep 6, 2001 | 05:09 PM
ScreaminDeamin85Z's Avatar
yes the hole needs to be 1 inch further back than the t-5. and you mean the slave cylinder right? that also needs to be changed, i dont know the part # but i do know that there are 2 diff slave cylinders, do a search and it should yeild you some part #'s for the slave cylinder.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-Jamex Springs...and thats just about it till summer!
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old Sep 6, 2001 | 08:33 PM
89ROC's Avatar
the shifter hole needs to be cut back 1-2"
The part no. for the T56 clutch slave/master cylinder is 12559912.
PurelyPMD
May 5, 2016 04:57 PM
tonys91rs
Oct 10, 2015 03:31 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
