How do I figure out the right stall converter size?
Old Sep 6, 2001 | 08:43 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Thanks guys
1987 T/A GTA 5.7L, Bored .020 and ported for .202 valves, edelbrock headers, flowmaster exhaust, JET STAGE II chip, Comp CAM, Adjustable fuel pressure, Airfoil, K&N filter, B&M stage 2 shift kit, and a home depot ram air(Hey it looks good and it works)
Old Sep 6, 2001 | 09:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The most precise way is on an engine dyno. You want one that stalls a couple of hundred rpm below your peak torque.
Chosing a converter stall speed should be left up to the manufacturer. Call up any of them. They'll want to know all sorts of information about your car and engine then they'll suggest the proper converter and stall speed for your combination. Not all converters are built the same and a converter that stalls at a specific speed on your engine will stall at a different speed on a different engine.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
suzuki949
Aug 28, 2015 08:07 AM
Jake_92RS
Aug 17, 2015 09:42 AM
