Six speed shifter getting hot
Old May 26, 2009 | 10:10 PM
Camaro383ci's Avatar
Car: 84 Berlinetta
Engine: Bottle Fed 383ci
Transmission: Stage2 T56 Ram powergrip HD clutch
Axle/Gears: Ford 9" Detroit tru track 4.11 gear
I just got my six speed swap done and im in the process of breaking in the clutch. I've noticed that when I drive for awhile the shifter gets pretty hot. Not the **** though. But the shifter gets hot enough to where you can grab it, you just can't hold onto it for very long without letting go. It doesn't burn your hand or anything but I pretty sure its not normal. Does anyone know what the flip is going on?
Engine temp is 170 on the highway and 180 in traffic.
Old May 26, 2009 | 10:51 PM
heff17's Avatar
Car: 89 Camaro
Engine: 383 w/ 450HP
Transmission: TKO-600
Re: Six speed shifter getting hot
mine does it two when ive been riding around for a while.
Old May 26, 2009 | 11:36 PM
Demon_Eater's Avatar
Car: 91 Camaro RS
Mine has done it too, here just tonight I got my camaro going and took it to work (I work at a Pepsi company just thought to say it) I let my friend drive it and he was talking about how the shifter was getting pretty warm.
I assume why mine is warm is because when I was following the instructions thread on how to swap in a 6 speed into a third gen camaro. they said cut two inches back (I think it was inches?) well apparently I cut a little more than I should have so theres a good gap from the shifter from the body that I cut. I figure its just the exhaust raising up (even when Im driving around)
But idk.. I could be wrong, I wonder if these transmissions easly absorb heat... -shrug- just my
Old May 27, 2009 | 07:33 AM
heff17's Avatar
Car: 89 Camaro
describes mine too, b/c i didnt put the rubber boot that goes back on the floor board. so i just have the trans sticking up out of a hole.
Old May 27, 2009 | 02:12 PM
Car: 84 Berlinetta
On mine though, i bought a big lower boot (the junky spectra boot from autozone 7"X8" in size luckily its hidden). It covers the entire hole. I made sure to cover the shifter hole and the hole for the automatic cable. It sucks when you leave holes in the body and you can feel all that heat coming through the hole while your driving.
Old May 27, 2009 | 11:51 PM
wanta427's Avatar
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
The shifter eventually ends up being the same temp as the trans . That's how my T-5 is too .
Old May 28, 2009 | 08:06 AM
Black91Camaro's Avatar
Car: 1991 Camaro RS
Engine: 350 carbed
Transmission: 6 spd
Axle/Gears: 3.42 10 bolt
Mine does that too! How warm does your engines get? Mine stays about 220!
Old May 29, 2009 | 03:30 PM
Car: 84 Berlinetta
Mine runs 170 on highway and 180 in traffic.
Hotrodboba400
Dec 10, 2019 07:07 PM
Strick1
Sep 4, 2015 07:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
