10 bolt ?
Old Sep 7, 2001 | 02:43 AM
JayZ28's Avatar
10 bolt ?
Can I build my ten bolt to handle 10 second, 650 hp or do I need to get a 9 inch? If a 9 inch is in the future who would you recommend?
thanx
speed is a good thing,
more speed is a better thing
86' SLOW LG4 bone stock
except for a K&N
Future Mods: T56
350-383
miniram
Old Sep 7, 2001 | 06:57 AM
ede's Avatar
ede
buy a ford rear, if it were me i'd buy from moser engineering in portland indiana
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 7, 2001 | 08:31 AM
82camaro's Avatar
Car: 82 camaro SC
10 bolt might handle it a few times, but will be a waste of money when it destroys itself. Go with the 9 inch Ford rear. Prepare your car before you install the killer engine, that way you don't break as much stuff.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
