Rear End Q's
Old Sep 9, 2001 | 07:18 PM
Sharpcorner's Avatar
Rear End Q's
I have an 89 with the 5 speed. I have the 3.08 rear I think. What size are the grears? What I mean is that some are 7 5/8 and other are 8.5. To make this simple I'm looking for the parts to convert to posi with my current rear. What do I need to look out for and what do I need to get? Thanks.
1989 Firebird Formula L03
Black with 5-Speed
Stock with Functional Formula Cowl Induction, Centerforce Clutch, KYB GR2 struts and GAJ shocks, 89k on the clock and running smooth.
Old Sep 9, 2001 | 08:37 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You will need to decide if its a 10-bolt or 9-bolt. I think w/ 3.08 gears, its more than likely a 10-bolt. If its a 10-bolt, it will be a 7.65" rear axle.
If your going to get a posi, your best bet is to get a "3" series posi, and some new "3" series gears to go w/ it. Right now, with the 3.08 ring gear, your setup is a "2" series.
If your on a budget or you really like the 3.08 gears, GM did make 2 series posi's. You might be able to find one used somewhere.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
