spohn torque arm with 12 bolt axle
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i just installed a trans mounted adjustable spohn torque arm on my moser 12 bolt, with the suspension loaded the rear mounting bracket is hitting the rear seat tunnel, anyone had this issue?
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: spohn torque arm with 12 bolt axle
Car: 1986 Camaro SC
that's the bracket i have with the double holes, my rear is centered, i'm not moving it.
Dunno what to tell you then.. If you're using the set of holes that move the TA inboard and your rear is centered, you may just need to use a BFH to clearance the tunnel area where it's hitting..
Car: 1980 Regal
Engine: 383 Superram
Axle/Gears: 12 bolt w/ 3.31 posi
I've got Moser's 9 in in my car and I had the same problem. But don't worry, it will self clearance itself. I know that doesn't sound like a good thing, but it did work really well on my car with no ill affects. You have to remember these aftermarket TA's are a lot bigger and bulkier than the stock TA. I am sure if the stock one was put back in there wouldn't be any clearance issues. You definitely need and adj ta anytime you use an aftermarket rear end to get your angles set correctly. So, that is the compromise we all pay.
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
