Question about alternative tranny fluids
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
I'm using Mobil Mobilefluid 424 Hi Torque tractor fluid in my t-braked turbo 400 thats backing my Turbo V6.Anyone try this fluid?What kind of results did you have?Any opinions?
Thanks,
Steve
1989 Turbo Trans Am's #124 and #850
1989 Turbo GTA
2001 Kawasaki ZX-6R
Thanks,
Steve
1989 Turbo GTA
2001 Kawasaki ZX-6R
Transmission: 4L80E/4L80E
I'm not familiar with that particular fluid, but I would assume it is a hydraulic-type without friction modifiers. I would also assume it is petroleum-based rather than synthetic.
Since your topic didn't limit the discussion to that fluid, I'll say I'm using AMSOIL Supershift ATF in my '57, which I know does not have friction modifiers. The shifts are very, very firm, and would probably be close to harse on the street if I didn't have a couple of quarts of normal ATF in it with the modifiers. Because it is synthetic, it reduces gear & bearing friction vs. petroleum-based fluids, keeping heat production down, is better able to withstand heat that is generated, and has stayed clear throughout this racing season. It isn't recommended for street use because of the harse shifting that can result. But, it's a great racing fluid.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
It works very well in high load (extreme duty) applications. It is very similar to my Pro-Fluid. It will not hurt anything. It does have friction modifiers and should work very well for you!
Car: 2013 C63C
Engine: M156 (P31)
I'm glad other people have heard or are using it,I just wasn't sure if what I read was true.Here is what I've heard
This fluid is designed for Catapilar and John Deer equiptment and has a hi sheer film strength so it provides better protection and lubrication for your hard parts(bearings,bushings,and planets).Hi film strength helps the clutches hold heavy loads at higher temperatures without breaking the oil film.It also has a higher viscosity and flash point than regular transmission fluid.This helps the fluid stay stable at much higher temperatures and dissapates heat easier.The biggest advantage is that this fluid will not burn like Dextron or Type F under high temperatures encountered during trans brake launches and building boost at the line.No modifications are required and it will not change your shift points.
So it looks like thats what I'm going with.
Thanks,
Steve
1989 Turbo GTA
2001 Kawasaki ZX-6R
Thanks,
Steve
1989 Turbo GTA
2001 Kawasaki ZX-6R
Thornburg
Aug 25, 2015 01:46 AM
db057
Aug 11, 2015 10:11 PM
