Power Braking, Bad or OK??
Old Sep 15, 2001 | 11:01 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
This debate has come up on the street racing board. Some people say that doing this doesn't damage anything. Could an experienced mechanic shed some light on this, I guess my word that it puts damage on the tranny and rear just isn't enough.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 15, 2001 | 12:23 PM
transfixleo's Avatar
Stalling against the converter should be limited to no more than five seconds according to all manufacturers and this is for esting a tranny anyhow. This creates a ton of heat in the converter. Now I know many people use this to launch at the strip but you are always taking your chances when you do things like this.
Old Sep 15, 2001 | 03:58 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
"Power braking" does indeed create a lot of heat in the converter, but if youre doing burn-outs you can wear-out and/or damage your rear brakes.
Ummm... overheating transmission fluid breaks it down quite a bit. NOT GOOD!
If you wanna do burn-outs, get a line lock put on your car. To keep from burning up your tranny fluid, leave off idle.
89GTAOz
May 16, 2020 09:31 AM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
stalkier
Aug 13, 2015 12:59 PM
