What could go WRONG :)??
Old Sep 16, 2001 | 11:51 PM
KED85's Avatar
I am offered a 700R4 Tranny for my 2.8.
It worked when it was removed from the vehicle. It has sat for awhile (about less that a year, let's say).
It's never been rebuilt and has had a good useage of life. The year of this tranny is I believe a 1986, from a V-6 Firebird.
NOW, the tranny is/has been sitting in a cold garage, flat, on its pan, with fluid in it. What could happen to it, to make it not operate correctly upon installing in my 1985 2-WD S-10 Blazer?
I will get another tranny torque convertor, use fresh fluids & filter. Maybe even a fresh seal or two (for the pump & the tail shaft seal).
What could go wrong with a tranny sitting out of action for a while that once worked proper?
Please educate me. It is to come from Wisconsin to Calfornia and I am getting it for basically FREE!
Please help both the seller and the buyer. Neither of us wants the deal to go sour, we are both helping each other on this deal.
Why was tranny removed from the running car? He swapped in a 5 speed stick shift set up in his Firebird.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Sep 17, 2001 | 02:52 AM
transfixleo's Avatar
If it has more than 50K on it, it needs a new Input Sprag, at very least.
Old Sep 17, 2001 | 10:48 AM
KED85's Avatar
THANKS FOR THE CONFIRM THIS COULD BE A FAIR WINNING DEAL, Leo!
Suggesting while replacing the "seals" also do this one extra detail.
Great.
NOW... Should I also replace the T.C. or may I just "have it drained (remove fluid for shipping)" and then reuse it?
I will not be pounding on this tranny. My S-10 Blazer engine is weak with age (211,500 miles), so I only need this tranny to function well.
AGAIN, THANKS FOR THE THOUGHTS & TIPS!
Chat Soon,
KED85
Karl
Old Sep 17, 2001 | 10:55 PM
KED85's Avatar
How "deep" need I go, to install the beefier sprang?
If I have the tranny on the bench and I replace the filter, some seals, etc, how much further to reach the sprang?
Chat Soon,
KED85
Karl
Old Sep 17, 2001 | 11:04 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I would change the front pump seal. I am kicking my self in the a_s for not changing it in my 84 4wd GMC Jimmy when I hade the engine out for a rebuild. After 10000 miles the son of a bi__h is puking out tranny fluid from the seal.
Guess what Im doing soon!!!!
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!! GREAT!!
Flowmaster exhaust
LT1 Injectors
Old Sep 18, 2001 | 09:17 AM
KED85's Avatar
That pump seal job was a given! I almost feel like upgrading the pump, but, why mess with what is in synch right now?
I only need it to move, not for performance, right now!
The engine is weak, so it'll be a perfect match for the tranny.
Chat Soon,
KED85
Karl
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
