putting a t-350 in my 82
Old Sep 18, 2001 | 03:00 AM
superman46's Avatar
I am putting a t-350 in my car i have some qustions thoe
1 its a shrot tail what kind of tail shat do i use i have a 200 but the tail dosent come off so is their 2 kinds
2I have a 700r4 in it will i have to get a new driveline etc or will the one i have work
3 its not a lock up tranney will it still work THANKS grat wed site
Old Sep 18, 2001 | 07:10 AM
bhaas's Avatar
First thing to do is measure the tranny you have in the car now and measure the TH350. If they're the same then you can use the driveshaft. Then your gonna need a troque arm adapter from Summit for that tranny. I have a TH350 in my car and was able to use the same drive shaft. It's also the long shaft. It's about 32" +/- an 1/8th or so. If you have a 700r4 in it now, you'll probably need to get a longer driveline. Just go to the boneyards. They're laying around all over the place.
Brad...
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
Soon to be T5 YES!!!
Old Sep 18, 2001 | 09:26 AM
superman46's Avatar
can i go and get a used tail out of a diff car they say 200 tali will fit the tranney but i have one and my dosent come off thanks
Old Sep 18, 2001 | 01:35 PM
bhaas's Avatar
Nope. Unless you get a new output shaft for the tranny. Just get a driveline at the junkyard. I just did a motor swap into a Ford Galaxie 500. Took the motor and tranny out of a 1980 Granada and the tranny was quite shorter. Bought 2 drivelines at the junk yard for $25. (Didn't want to make 2 trips in case it was wrong on the length) and one fit. Piece of cake.
Brad...
Old Sep 18, 2001 | 08:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
From what I can understand from your message you currently have a 700R4 and want to convert to a TH350.
A short tail shaft TH350, 6" tailshaft, needs a driveshaft from a 82-83 f-body that came with a 200c tranny.
If you use a long tail shaft TH350, 9" tailshaft, the 700R4 driveshaft is a direct fit.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Sep 18, 2001 | 08:46 PM
superman46's Avatar
i have a 700r4 in my car now i had a 200 in it the tail dosent come off mine its a 82 did they put 2 types of 200s in the camaros
Old Sep 19, 2001 | 04:14 PM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
Ok
Gm only had 1 th200c for all camaros and firebirds. The tailshaft is not removable. The drive shaft from your 200 is adirect swap for a gm Th350. I am under the impression you have already swapped a th700 in to the car. So you have found a drive shaft that fits and its not the 200 one. The 200 to 350 swap is simple remove 200 drive shaft, remove tranny, replace tranny with th350, then reuse 200's driveshaft.
I hope I answered you ?'s
Later
John
82 Firebird,408,Dart Iron Eagle 215's,Cam 229/239, .498/.520,TH350 Tranny, 750 Speed Demon carb, Hooker Headers(I.E. POS) Manual steering, Bfg DR's.
Check out my birds new home.
Best et 8.21 @84mph in the 1/8th
Jake_92RS
Jan 28, 2020 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
michealleger
Aug 26, 2015 03:29 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Fronzizzle
Aug 9, 2015 01:15 PM
