built v6 auto transmission highest hp rating?
Old Jun 6, 2009 | 03:09 AM
C_D_Z's Avatar
so when i build the motor for my car down the road I was wondering what is the most you can do to a v6 automatic? and what would be the highest hp you could put through it?
or is there a stronger v6 auto tranny that I could build up?
Old Jun 6, 2009 | 09:22 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: built v6 auto transmission highest hp rating?
The V6 and V8 autos are the same. The V6 may have fewer clutches and different valvebody programming, but if you do a performance build you change all of that anyway. I highly recommend a rebuilt kit from Pro-Built, a TransGo shift kit, and Corvette servos. A trans built with those parts is good up to 575HP.
Old Jun 6, 2009 | 04:07 PM
C_D_Z's Avatar
ok thank you, would a tranny shop be able to buy the kit and put it in for me, or would I need to buy it? I am only 16 don't know much about trannys yet so it would just be easier to have the shop do it.
Old Jun 6, 2009 | 05:49 PM
I would find a trans shop that will work with you. If I were you I'd buy the kit from Pro-Built with the other parts and give them to the trans shop. You need to find one that is willing to work on this type of project though, as this will not be a wham slam rebuild like a lot of trans shops are used to. Speak with Dana at ProBuilt and get his clearances for various assemblies that are different than stock so you can relay that info to the trans shop. Or, you could send your trans to him and have him do the rebuild. He's in California, which is at least on the same side of the country as Oregon. I had to do the rebuild myself with his input, because it was just too costly to ship a trans to California and back to Delaware. That being said the trans came out fine and works flawlessly (my first auto at the time too).
Old Jun 6, 2009 | 11:59 PM
C_D_Z's Avatar
And would this kit work? it seems to have the stuff you were talking about?
and is this the pro-built website?
http://www.700r4l60e.com/store/produ...&cat=19&page=1
Old Jun 7, 2009 | 07:43 AM
Yup, that's it. I installed the new GM Reverse/Input drum too. It's the better part out of the 4L60E. Otherwise that's everything you need.
Old Jun 8, 2009 | 01:06 AM
C_D_Z's Avatar
that kit would work in a v8 700r4 to sense you said the v8 v6 autos are the same?
I might be putting a v8 in it's on the cheaper side for motors.
Old Jun 8, 2009 | 12:58 PM
Yeah, the guts that have to be reused are the same. A V6 trans may have fewer clutches in it in certain spots, but all that will be addressed with the installation of the ProBuilt kit, as those are parts that will be replaced anyway.
Old Jun 8, 2009 | 06:58 PM
C_D_Z's Avatar
ok Thank you for anwsering my questions.
Pac J
May 17, 2020 10:44 AM
PurelyPMD
May 5, 2016 04:57 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
