200 MPH speedo.. anything needed?
Old Sep 18, 2001 | 08:03 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
im going to be installing a 200 mph speedo in my car.. im just wondering if ill need any different cables/wires so it knows its the 200 mph speedo and not the 145.
Old Sep 18, 2001 | 11:22 PM
Omar's Avatar
Where did you get the 200 from? Got a pic?
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Sep 18, 2001 | 11:37 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Should be the same. The standard for speedos, is like 1000 rpm's of the input (or I would imagine pulses from the vss would be the same) would be 60 MPH. I'm not sure on that, and I know GMTech knows, that's where I got it from!
Is this some sort of rare stock piece, or aftermarket?
Working on:
'84 Z28 LG4 305 with 208,000 original miles!
Dual electric fans (from a formula).
145 MPH IROC Speedo
430 HP 350 (ZZ430) Coming soon! (Building it myself, so I don't get those AWESOME valve covers!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
+ L1 Advanced Engine Performance
+ X1 Undercar Specialist
And....A sig. that's getting way too long!
Old Sep 19, 2001 | 06:54 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Autometer has had the 160 and 200 mph electro speedos for years.
IMHO the 140 stock speedo is plenty. If you looking at a speedo at 140+ mph.....
WTF are you doing????? The is NO time to be checking the speedo. Maybe the oil temp, oil pres, water temp, then you wanna check your speed????
Better be in the Silver State Classic. Even John Lingenfelter will tell you there is NOT enough time to check all vitals at TRC at 200+ mph.
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Sep 19, 2001 | 07:34 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
well i have the place bookmarket for the 200 mph speedo. there was a digital and the regular kind. im opting for the regular kind. to bad 60 mph is going to be were the usual 40-45 is all the other guages are in except this 1 and the tach. and yes im going to be doing the high speed driving
Infested
May 22, 2018 11:56 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
