Posi Conversion on My '88
Old Sep 18, 2001 | 08:09 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
I need a little help trying to convert my rear end to a posi. I bought a posi unit from ebay from a '96 camaro. I know I need to find 28 spline axles. The car was stock a '88 Sport Coupe with a vin "e" tbi 305.
What year Camaro's should I be looking for that have axles that will fit my Camaro?
Can I use the pinion from the '96? I really like that gear ratio so I would like to know all I need to set this up.
Would I have to change the races in my '88 housing to the same size as the '96? Or should I change the pinion bearings to that of my '88?
Please help. I am very capable of doing the labor. I may have a problem with pinion depth tho. Please any help would be appreciated
1988 Camaro Sport Coupe: Orignally: 305 TBI 700r4
Now: 1974 350CI, 2bolt,.030 over, Badger Flat Head Pistons w/ valve relief, Melling high performance street cam, GM Cast Vortec Heads, Edelbrock RPM Air Gap Intake, Edelbrock 600cfm w/ electric choke, GM HEI w/ vacuum advance, Weiand Low Profile Air Cleaner, Mallory 5 port Fuel Pressure Regulator, Mr. Gasket Throttle Cable Bracket, Corvette Shift Servo, 16" IROC Wheels, Every thing else is STOCK
Soon: 3.73 or 3.42, Gears, Hoosier Q/T
Old Sep 19, 2001 | 06:18 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
Please help
Old Sep 19, 2001 | 07:40 PM
ede's Avatar
ede
you should be able to use the 4th gens gear set. the races shouldn't need changed. look for a 90 and newer f body for the 28 spline axles.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Linson
Oct 24, 2025 02:00 PM
KO1
16
Oct 15, 2015 05:00 PM
