T5 repair
Old Jun 8, 2009 | 01:37 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
T5 repair
Hey guys, i am buying another 89RS today, T5 car, the trans just grinds when you let off the clutch, so i can say the tras is screwed,
Thing is, i have another T5 that i busted the 3rd gear out of, question is, as i have never been inside one, anyone here know the chances of making a good trans out of the two busted units?
I know i wont even know til someone busts it open for me and see the extent of the two, but how bad do they go when they do?
Old Jun 8, 2009 | 06:47 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: T5 repair
Well, it moved around on its own, maybe i will be able to make a single usable unit for not too much$$$$$$$$$$$.
Old Jun 9, 2009 | 03:04 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: T5 repair
It's possible, but depends on what's broken in both units. Your best bet is probably to just repair one trans, or both if you want a spare (that you could also sell to recoup some cash if you want). I've found that most transmissions break in the same way, so you may have two that have the same parts broken, in which case you won't have the parts you need anyway. I should be able to set you up with good used parts to replace whatever you've got that's broken. PM me if you're interested.
Old Jun 9, 2009 | 11:19 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: T5 repair
Excellent man, i will let you know as soon as i see what the deal is.
Old Jun 16, 2009 | 07:45 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: T5 repair
Turns out the one in the new car burned up the bearing due to lack of fluid but the gears are ok, so i am swapping everything that is good to one unit, should be fine.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
