355 sb+Stock T5=Fail?
Old Jun 9, 2009 | 10:19 PM
dead sailor's Avatar
Car: 82 Z28
Engine: 355 solid roller (395 stroker soon)
Transmission: t-56
Axle/Gears: 9 bolt posi
Yeah, putting a T5 in my 82 z28 with a 355 sb. How much HP can the T5 handle? What is a better alternative T56?
Old Jun 9, 2009 | 11:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 355 sb+Stock T5=Fail?
Originally Posted by dead sailor
= Fail?
Correct.
T56 would be a better choice, but a T5 will last if you don't abuse it too much.
Old Jun 10, 2009 | 01:49 AM
Camarslow's Avatar
Car: 1984 Z28
Engine: none
Transmission: none
What kind of power will that 355 be making? Remember when 3rd gens started getting the 350 around '87 (iirc) they put the 700r4 behind those suckers cause they were worried about bone stock 350's breaking the t5.
I wouldn't go with the t5, but that's just me. As far as an alternative to the t56 (which would be really nice), a tko 500 or richmond 5 speed are also viable options.
Old Jun 10, 2009 | 11:26 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Personally, i have beaten a T5 to death, motors that went into the 11s, BUT i kept stock clutches and radials, so it would bust the tires loose and smoke the clutch before it killed the trans, a L98 with a 100 shot finally killed 3rd gear.
Old Jun 13, 2009 | 11:29 PM
Car: 82 Z28
Transmission: t-56
The motor should be making around 350 hp. I already have the T5 so there's no turning back now. I'm just using it until I have enough money to get a stronger tranny.
Old Jun 14, 2009 | 10:33 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Just run it till you get the next trans, go with a T56 next, you wont regret it, except unlike me, you dont have a donor car, so get a T56 from a 98-02 camaro or firebird, that way you can leave in the stock bell housing and use an adapter plate that will be able to use the stock clutch setup, you just need a new cross member and possibly a shorter drive shaft.
Old Jun 16, 2009 | 10:45 AM
Car: 82 Z28
Transmission: t-56
alright thanks
JHX
Aug 29, 2015 02:30 PM
InfernalVortex
Carburetors
May 10, 2015 05:40 AM
Slayze
Jul 29, 2013 06:05 PM
neagan
Jan 28, 2008 11:18 AM
80Sierra
Jun 24, 2006 02:02 PM
