will the turbo 350 transmission fit in my car?
Old Sep 22, 2001 | 08:44 PM
PlayBoy's Avatar
85 firebird v6 switching to chev 350 with turbo 350 tranny will it fit?
Old Sep 23, 2001 | 09:03 AM
ede's Avatar
ede
as far as i know all gm auto trans will fit, the th350 for sure will fit. you'll need the 9" tail shaft to keep from having to change the drive shaft. by a b&m pn 30299 for about 80 dollars and you won't have any more problems than doing a r&r on the stock trans.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 23, 2001 | 03:28 PM
transfixleo's Avatar
Yes but personally I think you are better with an O/D such as a 700, properly built of course.
Old Sep 23, 2001 | 03:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends what you want it for and what your rear end gearing is.
For the street a 700R4 is fine but it's heavy and has poor gear ratios for racing.
If you have non performance gears in the rear end, 3.45, 3.73, 4.10 etc then a TH350 will do just fine on the street. It did for decades in older cars.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
jhawkeye
May 25, 2022 06:33 PM
Terrell351
Jun 13, 2021 01:13 PM
camaro71633
Sep 1, 2015 10:24 AM
mizz0313
Aug 12, 2015 06:45 AM
milk
Aug 10, 2015 06:26 PM
