locking and non locking tc's
Old Sep 9, 2001 | 01:28 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
what is the diff
and also what is a manual locking one like?
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Old Sep 9, 2001 | 01:35 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Locking torque converters have a clutch inside them to eliminate slippage, which reduces temperature and increases mileage. There are no "manual locking" converters, the clutch is controlled by fluid signals from the transmission. You can manually control the lockup by playing with the wiring.
Old Sep 9, 2001 | 01:50 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
oh
well if i took out the computer in my car....which would b the best to go with?
Mods-
K&N Air filter
Old Sep 9, 2001 | 06:04 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The easiest way is just to put a switch between the wires to the A and F terminals on the ALDL connector. Turning on the switch then will lock up the torque converter in every gear except first. If you want automatic control without the computer, there are a number of kits on the market that you can buy. If you're a little more adventurous (or cheap) you can modify the wiring harness inside the transmission to do the same thing for nothing.
Old Sep 9, 2001 | 09:14 AM
transfixleo's Avatar
You NEED the locking converter on the street. On an '84 you should have a TCC valvetrain in the VB. This means that you can control when L/U accurs through spring changes in that area of the VB. Then you can wire the solenoid on all of the time.
Old Sep 9, 2001 | 03:17 PM
RyanSS's Avatar
Eliminate slippage between what? What are the benefits of both?
89 RS parts car
Daily driver 91 RS auto LO3 63k
New project- 89 Formula 350 WS6
383 or 400 to come!
Old Sep 9, 2001 | 06:33 PM
82camaro's Avatar
Car: 82 camaro SC
The only benefit of a non-lockup is it doesn't have the clutch to go bad. Lock-up reduces rpm going down the highway. Normally a torque converter slips all the time, wasting energy(efficiency). Your tranny will run cooler and you will get a bit better mileage.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 9, 2001 | 08:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I haven't seen too many locking converters with really high stall speeds either.
Old Sep 10, 2001 | 02:41 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Good topic, I often wondered about this. What would the physical difference be when driving the car, would it feel different if you nailed it in 2nd for example?
Old Sep 10, 2001 | 07:28 PM
nsimmons's Avatar
I have a switch to control mine..i have the option of off (no lockup period) auto(let tranny decide) and ON (force lockup)
i dont use the lockup around town..its very nice..normaly right after the 2nd gear shift the converter locks up and lugs the engine..also when the converter is locked up and you stab the gas the car will jerk like a stick shift. when its not locked up the rpms climb a bit and the car will accelerate, its much smoother,another benefit is yout dont have to nearly floor it to get some power to climb a hill.
Nick Simmons
Light Bronze 1984 Vette Auto, Ported and polished Intake,no swirls, K&N, MSD, no smog pump, Ram air/Cold air intake, no cat
Old Sep 11, 2001 | 04:48 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
nsimmons, I'm guessing you don't have the original transmission, right?
Old Sep 13, 2001 | 03:11 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
So what is the disadvantage of keeping it locked all the time? Surely that is the way foward>
Old Sep 13, 2001 | 03:13 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
<font face="Verdana, Arial" size="2">Originally posted by 82camaro:
</font>
Ahhh sorry, should have re-read. I love retorical questions
Old Sep 14, 2001 | 12:56 AM
RyanSS's Avatar
Can you put a switch like nsimmons has on a stock trannny or if what do u need to do it?
89 RS parts car
383 or 400 to come!
Old Sep 14, 2001 | 04:17 AM
Yes you can run a switch.
Old Sep 16, 2001 | 11:55 PM
RyanSS's Avatar
How would you go about making a switch such as this?
Also, i have been smelling burnt tranny fluid when at WOT, what can cause this?
89 RS parts car
383 or 400 to come!
Old Sep 17, 2001 | 02:50 AM
You can purchase them from B&M, etc.
Old Sep 22, 2001 | 06:35 PM
nsimmons's Avatar
yes i have the original tranny..i heard it was bad to run it locked all the time,my tranny makesfunny noises when its locked and i manualy shift it
1984 Z51 Auto, Ported and polished intake, K&N, MSD, Ram air/Cold air intake, no cat, no AIR, no egr, no swirls plates
Old Sep 22, 2001 | 08:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Something's not right then, Corvettes might be different, but I don't think an 84 700R4 shouldn't be locking up in 2nd. TCC lockup was still partially controlled by the valving inside the transmission in early 700R4's.
Old Sep 23, 2001 | 04:17 PM
Early 700's had HORRIBLE shift timing, INCLUDING the L/U! Yes they can L/U in 2nd. Even my '88 does.
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
