700 tranny noises
Old Sep 24, 2001 | 08:48 PM
Rd90RS's Avatar
700 tranny noises
I have a '90 V6 RS with a 700 trans and when I get moving about 20 mph, I heard a whine that sounds as if it is coming from the transmission. It countinues to increase in pitch as I accelerate, or when I move the shifter to neutral and rev slightly the sound increases as well. It does not quit until I am moving less than 20 mph, and is quite at an idle or reverse. It shifts fine in all gears, and covertor locks normally. Sounds like maybe the pump in the trans??
Old Sep 26, 2001 | 04:06 AM
transfixleo's Avatar
It could be a bad converter, plugged filter or a bearing in the tranny. If it goes away in 3rd but is ther otherwise then it is the planetaries.
Old Sep 26, 2001 | 04:43 AM
Rd90RS's Avatar
The sound does not go away unless the car is moving less than maybe 20 mph or so and not under a load. It goes thru all the gears just fine, and I do get lock up from the converter. I am going to try the filter change first, as the car has a lot of miles on it. Also, when you coast in neutral from 50 mph or so the sound disappears too. Thanks for the reply transfixleo!
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
GouldyGTR
Sep 7, 2015 09:05 PM
