What driveshaft do you reccomend?
Old Sep 24, 2001 | 07:04 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
Which driveshaft would you reccomend? I already have the stock aluminum shaft but it's giving me vibrations at 75+ MPH. I was looking around at aluminum and carbon fiber ones. They range from $300-$800. A little steep, isn't it?
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Sep 26, 2001 | 11:07 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Nice GTA. Sounds like you have maxed out the 22 lb injectors too.... I have been burning my own EEPROMs for a little while now and that, along with Fuel Pressure tuning has proven that my injectors are limiting my current setup (BLMs just won't come down any farther...). And I read quite a few times that 22lb injectors are good for 400hp..... buncha B.S.
Anywayssss..... I have an Inland Empire Aluminum driveshaft and I got it from Summit for around $350 I think. It is 3" and comes fully balanced and assembled with U-joints. It has performed flawlessly for me. It was nearly as heavy as my crappy steel OEM shaft!! That is a good thing though, as that would indicate the strength of the shaft and support their claims of it being good to like 600 ftlbs. I originally swapped the driveshaft out for vibration issues at high speeds but the added strength is nice to have.....
Laterzzzzz
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
89newfun
Sep 16, 2015 09:28 AM
