85 IROC Shifter Button Reattachment
Old Sep 21, 2001 | 12:30 PM
texasgt's Avatar
Car: 2003 HD 1500 4 door Chevy
Engine: 6.0
Transmission: 460LE
I am trying to find the actual piece / clip that holds the push button INSIDE the shift ****. I am almost done restoring the interior so I want to finish the punch list. The car came with the button laying inside the ****. I just cant locate the right fastener for the button to attach to the rod assembly.
Somebody end this dilemna PLEASE!!!
Old Sep 26, 2001 | 03:06 PM
texasgt's Avatar
Engine: 6.0
Transmission: 460LE
Somebody please respond !
Does anyone have a parts manual that can decipher the breakdown of the ****?
Old Sep 27, 2001 | 10:14 PM
Nordbert's Avatar
If your shifter has a round pushbutton of
about 3/4" diameter, you will have to get the clip from your GM dealer. It slips over the end of the flat rod and has tangs that engage the hole that is drilled thru the rod.
It also has tangs that dig into the button
when you push it down over the rod. Pull the
shift **** up into place and slide the
horseshoe clip thru the slot in the ****
and around the groove in the shift tube.
These directions should work on the upgrade
shift *****, too. You might have to order a
box of 5 to get one! Check GM part #9797188
GR 4.006 CLIP
BewleyBizzIROC
Feb 3, 2020 09:52 AM
NBrehm
Aug 25, 2015 11:49 PM
stalkier
Aug 21, 2015 01:54 AM
smooth
Aug 18, 2015 06:34 PM
mustangman65_79
Aug 11, 2015 03:17 PM
