Just did T56 swap..need to tune?
Old Jun 15, 2009 | 07:05 PM
Teds92RS's Avatar
Car: 1989 Camaro IROC-Z
Engine: Lt1
Axle/Gears: Quick performance 9" 4.11
I just finished my T56 swap into my 89 IROC, do I have to tune out the tq converter lockup or anything? I went for a quick drive around the block before we had a downpour and my check engine light came on for a few seconds when I was in 3rd gear then didn't come back again. Even while I had it idling in my driveway and just moving it around the garage.
Old Jun 15, 2009 | 07:51 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Just did T56 swap..need to tune?
Did you wire the VSS to the ECM? The T56 VSS signal isn't directly compatible with your '89 VSS. Without tuning the PROM to tell it you have a manual trans now, your idle will be higher than normal, trying to overcome the TQ conv load.
Jumper A-B on your ALDL if you don't have a scanner, and pull the code to see why the SES light came on before.
Old Jun 15, 2009 | 08:46 PM
Teds92RS's Avatar
Engine: Lt1
makes sense; I don't have the VSS hooked up and my idle was a good amount higher than normal.
Old Jun 16, 2009 | 02:01 PM
Teds92RS's Avatar
Engine: Lt1
It's throwing code 24, VSS. So looks like I just have to tune that out. Thanks for the info
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
sammy52401
Nov 11, 2015 07:20 PM
el_muerte
Sep 16, 2015 12:01 AM
