Clutch disengagement problem - T56 swap
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Guys, I just fired my 84 back up after swapping in my T56. I was trying to run it through the gears while it was on the stands and it was shifting really hard and sometimes refusing to go into gear at all.
It seems to shift fine with the motor off, so I'm suspecting the clutch isn't disengaging completely.
Another thing I noticed is, with the motor off and the trans in neutral, I can spin the driveshaft easily with one hand. If I get someone to put it in 1st and put the clutch in, I can't budge the driveshaft even with both hands. Should I be able to? I would think so, although it might be a tad more difficult since I'm turning the gears in the tranny now too...
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro Sport Coupe ZZ4 350 M6 -- '84 Olds Cutlass Supreme 231 A3
'91 Medium Blue Metallic Z28 400 A4 -- '99 Navy Blue Metallic Firehawk #120 346 M6
BlackphantomZ28
Apr 24, 2016 08:14 AM
rsrmoore
Aug 7, 2015 08:44 PM
