What to do about crossmember bolts???
Old Jun 15, 2009 | 07:07 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
I just finished installing a TKO 600 and am bolting up my modified stock crossmember with some shims when both left bolts of the crossmember strip. The problem is that the threads on both bolts look fine, so that means its the threads inside the unibody... but what is threaded? a welded nut inside there? I don't know what to do besides drill a big hole and weld a nut inside it.
Anybody ever have this happen before??
Old Jun 16, 2009 | 07:47 PM
brodysZ28's Avatar
Engine: 383
Re: What to do about crossmember bolts???
ok well i got new bolts for the crossmember and they sinched up nice, I guess the threads on the bolts weren't fine after all...
Old Jun 16, 2009 | 08:00 PM
wingers383's Avatar
Car: 92 Chevy Camaro
Engine: SBC 383
drill them and tap them for 7/16-14 and get rid of the metric ones. just a thought. that is what i did with my spohn cross member,
Old Jun 17, 2009 | 05:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if the threads on the old bolts look fine, it is a good chance that the bolts in the subframe are bad, even if new ones fit, it could be a fluke. I would really check and make sure they are ok before you drive the car. Would hate to see the trans fall out.
Old Jun 18, 2009 | 07:38 PM
brodysZ28's Avatar
Engine: 383
yea, idk, maybe it was a combination of both of them being half stripped, but when i got new ones in gave just enough bite to hang on. I brought down a drill and tap when i did it just in case i had to do that, but its been holdin fine so far.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
