Anyone have a TH400 installed in there 3rd gen?
My buddy was thinking of doin this to his IROC, and wants a trans brake. Anybody have any difficulty? I know Sphoen makes a crossmember/torque arm for it. Is there any other problems you ran into?
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I used the Hurst cross member kit and the stock torque arm on my my car. You will have to get a drive shaft cut and balanced.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts
www.koolmeister.com
Miles
88 427 Camaro
)www.koolmeister.com
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Better upgrade the differential too. A transbrake will destroy that tiny ring and pinion.
As mentioned above about the driveshaft. The TH400 output yoke is larger than a 700R4/TH350. You'll also need a TH400 yoke.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
