Lost D and OD
Old Oct 6, 2001 | 02:47 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Lost D and OD
I just lost Drive and Overdrive on my car yesterday. Without any warning. It was fine, I was on the highway for about 30 min, and stopped for a bout 10 min at my GF's house. When I go to leave, my car didn't have D or OD. It just revs at about 4k RPM, and does about 30 MPH.
Second gear works perfectly. Which I thought is odd because wouldn't that mean that the band that is on 2nd and 4th gear still works?
There is a wierd ticking noise that seems to be coming from my console. Not sure what it is, I thought it just may be the tranny.
Can someone help me?
Third Gen Project - Website now defunct because crosswinds sucks
1989 305 tbi Camaro RS Red/Red
Ram Air II Hood
Centerline Champ 500 Rims
Edelbrock Open Element
MacEwen White Faced Guages
Old Oct 7, 2001 | 03:40 AM
transfixleo's Avatar
In Man 1 and 2, line pressure is greatly increased so that if, let's say your Forwards were slipping badly at normal pressure that they might grab with the added pressure.
Let me try and clraify this though. If you go to take off in O/D or D, it still slips to @4K, right? Or does it take off OK but it doesn't shift and gets to 4K?
The reason I ask is different 'working' combinations would mean different things.
Old Oct 7, 2001 | 11:24 AM
Sonar_un's Avatar
Car: '86 T/A
Ok, when I take off in D or OD. It starts fine, in first, and then goes to second gear. When it tries to switch to third gear. The RPM jumps to 4k or so, and my max speed is 30MPH.
Ram Air II Hood
Old Oct 8, 2001 | 03:52 AM
OH, now I get it. Your 3/4 Clutch pack is toast. Common problem.
ZZ3Astro
Aug 13, 2019 12:57 AM
djmarch
May 8, 2016 11:32 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Jynx88
Oct 4, 2015 08:19 PM
3.8TransAM
Sep 27, 2015 08:37 PM
