All of those with the Borg worner 9 bolt rear end...
Old Oct 6, 2001 | 05:12 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Have you ever had trouble with the cover or the rubber plug leaking, especially under full throttle, how did you fix it?
Old Oct 7, 2001 | 11:10 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Not under the conditions you describe. But I did seal mine with silicone gasket sealer when I filled mine once. I had a minor weep and didn't trust it.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Oct 8, 2001 | 02:09 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, mine leaked. Sealed it like Lon said and all is good now.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 8, 2001 | 02:10 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Mine leaked like a sieve. I tapped the hole for a pipe plug.... I believe I used a 1/2" or a 3/4" plug.... I can't recall
Old Oct 8, 2001 | 06:47 AM
ausrs's Avatar
one thing with the 9 bolt ,the rubber plug gets hard with age ,heat etc
buy a new plug in aus they are only $3 bet they would not cost any more over there !
Old Oct 8, 2001 | 08:25 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
No problems with the plugs. Other leaks tho.
Had a cracked cover when I got the chicken - new cover was about $20. Now that cover has some nice dings and scraps inside of it when the 3.45's went boom.
Had problem the other day because some of the bolts backed out (ie: got loose) of the cover after the 3.70 change so I got a set of 5/16" coarse 3/4" long serrated flange bolts. Since I got 2 9 bolts I ordered a set of Mr. Gasket oil pan bolts for a mopar (pn 6088) that came with 20 of them for $9... that's almost cheaper than trying to find 9 at Home Depot.
'89 Formula - Thunderchicken - 355 Vette L98/T-56/3.70 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1nastygta
Aug 8, 2015 07:38 PM
