LINKAGE OR INTERNALLY SLOPPY
Old Jun 23, 2009 | 11:16 AM
TAGTASCOTTY's Avatar
Engine: 408ci Stroker, 520hp 515Ft.Lbs.
Transmission: Outlaw 700r4
Axle/Gears: 3:73
I just bought a new 700r4 from trans depot that is supposed to be capable of 575 hp. I have installed it and i know the the linkage is correct, but it will not go into park, also it will not shift into 4th gear but 3rd is fine. t.v cable is set correctly as well, Any ideas would be greatly appreciated. Thanks!
Old Jun 23, 2009 | 11:46 AM
Axle/Gears: 3:73
Re: LINKAGE OR INTERNALLY SLOPPY
Anybody ???????
Old Jun 27, 2009 | 12:03 AM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Shifter cable housing broken.
Old Jun 30, 2009 | 01:18 PM
Axle/Gears: 3:73
NEGATIVE BRO. I'M THINKING STICKY VALVE ALSO ON THE 4TH GEAR THING BUT DEFINATELY SLOPPY ON THE INSIDE
budowski
Carburetors
Oct 2, 2015 10:16 AM
mfp189
Sep 27, 2015 09:25 AM
IROCNParts
Sep 24, 2015 10:50 AM
scottmoyer
Sep 7, 2015 07:06 PM
greenyone
Sep 2, 2015 03:39 PM
