Another can't shift thread
Old Jun 25, 2009 | 04:56 AM
1 Quick T/A's Avatar
Car: 92 Firebird
Axle/Gears: 3:42
My 92 Firebird won't hardly shift into 1st gear a lot of times. It's the original T-5 /305. The rest of the gears seem to shift ok. But sometimes 1st shifts ok, what gives? Thanks in advance.
Old Jun 25, 2009 | 09:31 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: Another can't shift thread
So you can't downshift into first sometimes? I need more specific information before I can diagnose this. Is it speed dependant? In other words is it tough to downshift at say 25mph, but easy at 15mph. What happens when it doesn't want to shift? Noises? Stick won't move?
Old Jun 27, 2009 | 09:54 AM
Car: 92 Firebird
Axle/Gears: 3:42
Thanks for the reply. I don't really know on the downshifting, It's stiff as hell trying to get into 1st at normal idle. No problem while shifting into all the other gears. No noises while trying 1st, other than the sycronizers grinding while trying to get into reverse, and it's done that since i bought the car new.
Old Jun 27, 2009 | 10:24 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Had an '84 berlinetta that did something similar to this. Had gears 1-4, but they were very difficult to shift in to, and 5 was impossible. My problem ended up being a bent locking pin on the shifter that had worked its way out. It was an easy fix.
Old Jun 27, 2009 | 10:48 AM
What if you try and put it into another forward gear? Does it do the same thing in 3rd for example?
To keep from grinding reverse put the trans in 2nd and then go into reverse. No more grind.
F-body driver
Mar 6, 2023 11:44 AM
Linson
Sep 21, 2015 01:08 PM
TheTraut88
Sep 11, 2015 05:16 AM
89fast5oh
Sep 8, 2015 09:55 AM
tonys91rs
Sep 2, 2015 07:07 PM
