Need +500rpm from 4L60
Old Oct 10, 2001 | 04:48 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
I have a 93 Caprice 9C1 with the L05 TBI 350 and it currently upshifts 1-2 and 2-3 between 4600 and 4800rpm. These are pretty good shift points. WOT 3-4 is lower, around 4200 I think (~85mph with a 3.42 rear).
Anyway, I am about to buy an LT1 cam and I think I should adjust the tranny to shift about 500rpm higher than it is now. My hunch is that the TV cable will not make THAT much of a difference, and so I will need to attack the governor. Can anybody confirm this? How should I go about modifying the governor? Is there a factory replacement that shifts in the 5000-5200rpm range?
Otherwise, I can always manually upshift when I want to totally tap out the engine...
Thanks.
Kevin Moore
Old Oct 10, 2001 | 05:46 PM
Pro Built Automatics's Avatar
Try a lighter weight governor (V-6) this should get you the 5,400-5,600 rpm WOT shift points. Set the TV cable up as transfixleo says, that is the only way to get it right.
Old Oct 10, 2001 | 05:55 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Those shift points seem a little high...I might just manual shift it. I can also dyno it and see if I am losing performance by upshifting too early.
Also, my TV cable is current adjusted to spec (i.e. the tighten it then floor the gas approach).
Kevin
<font face="Verdana, Arial" size="2">Originally posted by Pro Built Automatics:
Try a lighter weight governor (V-6) this should get you the 5,400-5,600 rpm WOT shift points. Set the TV cable up as transfixleo says, that is the only way to get it right. </font>
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Linson
Nov 12, 2015 08:09 PM
C409
Sep 1, 2015 03:42 PM
Ryan_Alswede
Sep 15, 2001 09:28 AM
90RSconvert
Sep 25, 2000 10:07 AM
