torque converter lock up
I have a 700R4 in my 85 IROC and I disconected the wires to the transmission so the torque converter wouldn't lock up. it's nice for down shifts and won't lock up in third any more but my gas milage has decreased. My questions were is the trany ment to lock up in third and which wire do I put a switch on to enable and disable the lock up???
Thanks,
JJCIROCZ
Thanks,
JJCIROCZ
Car: 82 camaro SC
Put a switch on the ground wire--should be the black wire I think.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
Hotrodboba400
Sep 2, 2015 07:28 PM
