BOP TH400
Old Oct 12, 2001 | 08:02 AM
z28dan's Avatar
BOP TH400
Does any know of a good trans place in the burbs of chicago?
My dad is looking for a BOP TH400 for his 69 GTO. This car is a driver so he wants trans that can handle a heathly 455 and a 355 rear gear. But he doens't want the neck breaking shifts (old fart). He is trying to stay away from TCI and such, he wants more of a home brewed trans. Any ideas?
1988 L98
Vette Heads/no EGR
SLP Headers/Y-Pipe
ARAP bin
Old Oct 12, 2001 | 08:22 AM
Nordbert's Avatar
I recommend that the "Old Fart" get a copy of Ron Session's Turbo 400 manual and rebuild it himself if he has the time and
a little mechanical aptitude. Ron's book
has a lot of pictures and is written for the
novice rebuilder.
Old Oct 12, 2001 | 04:56 PM
transfixleo's Avatar
Get a TransGo Reprogramming Kit but stay on the conservative side as to hole sizes. They give you two sets of gaskets just in case you want to go bigger.
Old Oct 13, 2001 | 06:27 AM
Pro Built Automatics's Avatar
I agree with transfixleo on this, just make sure he is using the sprag style direct drum (1965-1971) then you will be able to use the Borg-Warner 34 element intermediate sprag. If not locate a used one if possible, otherwise Aceomatic Recon sells one. Talk to your parts supplier on this. If this is to much trouble, call me and I can get you all the HD parts you need to rebuild this right & the 34 element sprag (along with tech tips).
darwinprice
17
Oct 11, 2015 11:51 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Kenwood
Sep 11, 2015 12:50 PM
need4speed
May 7, 2001 07:29 PM
