Loud moaning from rear... u-joint? differential?
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Hey everyone.
When I turn at low speeds, (at sharp angles) my rear end is making a loud moaning noise, which vibrates the entire car.
I was wondering, I just had the differential fluid changed out, and a posi additive added, and it still makes the same noise.
Is there a chance this might not be my differential? It seems so loud, im not sure if the differential could be making the noise. I read that sometimes faulty U-joints can cause vibrations and noise like this.
I was also wondering if it could be thr rear brakes, execpt for the fact that sometimes when i drive over bumpy terrain, i get the same noise.
If anyone has any clues, please post!
Thanks!
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
Doesn't know enough about cars.
AIM: jesusathome
Thanks!
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
AIM: jesusathome
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'd check the bearings and definitely the u-joints along with the posi while you're down there. u-joints will sound like a moose when they're bad. Good luck..
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Are you sure the posi additive was put in? Mine did the same thing after the fluid was changed. They didnt put the additive in, after I poured the additive in it worked fine.
90 IROC
SuperRamed 406
Trickflow 23* heads
90 IROC
SuperRamed 406
Trickflow 23* heads
Alright, Does anyone have a picture of where i could add this fluid too on my differential? Im sure there is a bolt somewhere or someway to pour this additive in.
I was charged for the additive, so i figured they added it.
Also, i noticed when i push the breaks lightly, and let the car roll forward a bit (on uneven roads) i can get it to moan. I would think it was the breaks, except that the sound happens sometimes when the breaks aren't being touched. I also dropped in to neutral and coasted, just to make sure the breaks wern't slowing me down, (they were not).
Thanks for help, and any more suggestions! I have tossed 3 grand into my car already in the past year, and shes still giving me problems. She is a very naughty girl!
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
AIM: jesusathome
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
AIM: jesusathome
