Clutch sizing/effectivness question.
Old Oct 19, 2001 | 01:53 PM
Jester's Avatar
My stock T5 clutch is 10.5" and uses a 153th flywheel IIRC. I'm thinking of converting it to a 168th flywheel. What size clutch do they use..11" or 12"? Also, how much grip advantage does a larger one really have?
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Oct 19, 2001 | 03:08 PM
ede's Avatar
ede
as my wife always says bigger really is better. do the math, you gain a lot more surface area going from 10.5 to 12" the preasure plate also is part of the whole system. i'd run the biggest i could in a mc leod clutch
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 19, 2001 | 04:24 PM
Jester's Avatar
Your wife just says that because she's been with me and doesn't care about massaging your ego
Old Oct 19, 2001 | 07:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They use an 11" clutch. And they won't fit in a stock F-body bell housing.
ICON Motorsports
Old Oct 19, 2001 | 07:46 PM
Jester's Avatar
Well I guess that answers that. Out of curiosity..what does the 12" clutch I've seen listed fit?
JSP Motorsports
ICON Motorsports
Old Oct 20, 2001 | 09:48 PM
zslug's Avatar
Jester, that's a truck clutch, I used one in a '67 Camaro some years back, a 6cyl to 302 swap. That monster flywheel hurt my throttle response quite a bit, but it did cut down my rpm drop at launch.
It also required a bigger bellhousing, and a bellhousing-mounted starter.
That was 20-odd years ago, and I used it because I had it laying around the garage, and I was looking for all the clamping force I could get! I have to wonder, though, if the mass of that flywheel contributed to breaking the crankshaft in that engine... I replaced it with a 350 and a standard clutch setup, with much-improved throttle response. The 350 actually revved faster than the 302 with the heavy flywheel (with the same intake & cam!)
Zslug
May the road rise to meet your treads...
'84Z, 5sp, stock 305, Edelbrock intake, GTA wheels
Old Oct 21, 2001 | 01:39 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yah, 153 tooth is the biggest flywheel that will fit in a T5 bellhousing. Get a McLeod 11" clutch and be happy.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
