funny acting overdrive
Old Oct 22, 2001 | 12:53 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
i just finished installing a motor in my 85 z28. i went with a 1980 305 with some mods i had laying around i kept the 700 r4 that was in it. my question is the 1 2 3 shifts are good when it hits 4th the rpms drop dramaticaly and then slowly rises back up also i had to install a non computerized lock up kit and a new kickdown cable cause i went to carb. any ideas?
[This message has been edited by Bobbyz (edited October 21, 2001).]
Old Oct 22, 2001 | 04:07 AM
transfixleo's Avatar
Do you have a carb meant for a 700 or a 350?
Old Oct 22, 2001 | 11:49 AM
Bobbyz's Avatar
Engine: 350 "ZZ4"
dunno it's a holley 600 cfm carburetor the car that the engine in it before had a th 350 in it does that make a diff.
Old Oct 22, 2001 | 02:29 PM
Yes it does make a difference. The pull point will not be correct to give you the proper geometry. You see, the 350 kickdown cable just has two jobs; part throttle 3-2 and WOT KD. It has a modulator for pressure control and shift delay. The 700 does everything through the TV cable and it is very precise. It has more travel than the 350 because of these differences. I do believe you can get an adaptor for your linikage though.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
Luigytico09
Oct 1, 2015 08:46 AM
ironbmt
Sep 27, 2015 06:00 AM
