What are the signs of an ailing torque converter?
Old Oct 23, 2001 | 05:26 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
My vibration problems have pretty much been narrowed down to the tranny. A local tranny guru(known county wide for quality work) seems to believe that it's the converter from the symptoms I told him over the phone. I'm taking it to him later to have him drive it to see what's going on.
The symptoms are as follows:
1)Vibration at 60mph on up at 2100 rpm and up in overdrive.
2)the driveshaft has been balanced as well as the wheels and tires.
3)With the rear raised and supported the car was run through the gears to see if anything else was amiss. This was when the vibration showed itself as coming from up forward of the driveshaft and not from the shaft back.
I'm looking for as much info as I can find so I can make the correct choice of action. Can you guys help?
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,high flow cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit and torque arm,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
89fast5oh
Sep 8, 2015 09:55 AM
