how many quarts is exactly used on a T-5 Tranny?
Old Oct 22, 2001 | 01:00 AM
vortech305's Avatar
i have a 88' t-5 that i believe came out of a TBI 305 motor, how many quarts exactly goes into the t-5 i was told 3 is this true, Is it also true that i must use Dextron III fluid??????????? i need info ASAP
Old Oct 22, 2001 | 10:41 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Also, where is the fill hole located?
Old Oct 22, 2001 | 02:02 PM
zslug's Avatar
I think it's 3.5 qt, and yes, use DexronII or better atf. Do NOT use typeF!
The fill plug is about halfway up the side of the gearbox.
Zslug
May the road rise to meet your treads...
'84Z, 5sp, stock 305, Edelbrock intake, GTA wheels
Old Oct 22, 2001 | 02:11 PM
86Chicken's Avatar
Make sure you use the right fluid for your tranny. NonWC use gear oil and WC use ATF. If you use the wrong one you could wreck something.
Dale
Old Oct 22, 2001 | 02:49 PM
Pukka's Avatar
What color is gear oil? I have red liquid in my T-5, which should be ATF...right?
Old Oct 22, 2001 | 03:25 PM
86Chicken's Avatar
Yup. Red is ATF. If you have not had any trouble with it in there then keep using it.
If a nonWC T5 has ATF in it has a higher tendency to grind the gears and overall not work as well.
Dale
Old Oct 22, 2001 | 05:39 PM
vortech305's Avatar
Hold on im getting confused here with this ATF AFT BFT TFB or whatever the name is. The tranny that i have came out of a 89 305 TBI, so im guessing its not a WC. Just today i put Dexxron III transmission fluid, is this right, or was i suppose to put Gear oil, what the hell is gear oil?, Could u guys be more specific? Im a virgin to T-5's
Old Oct 22, 2001 | 05:40 PM
vortech305's Avatar
whoops sorry the T-5 came out of a 88' 305 TBI camaro
Old Oct 22, 2001 | 06:16 PM
plain82's Avatar
Still a W/C. Used in Camaros from 88 up.
Old Oct 22, 2001 | 09:10 PM
Mike89GTA's Avatar
Here's a tip, fill the transmission up from the shifter hole. It's way easier if you know how to take the center console apart and you don't get messy. Or buy a pump to put it in the normal way, but it's still a pain..
Old Oct 22, 2001 | 09:38 PM
Camaroman's Avatar
the T-5 I just rebuilt in my mustang took 2.5 quarts of ATF.
Dont worry...my camaro will be alot faster than the rustang.
Old Oct 23, 2001 | 01:33 PM
vortech305's Avatar
wait, i already installed the t-5 into my camaro and i just put the Dexxron III transmission fluid(which was like watery red) into the t-5, How can i tell if its a WC or not, is there a mark on the t-5 that i could possibly see from under the car?
Old Oct 23, 2001 | 02:32 PM
Pukka's Avatar
For what its worth, the Borg & Warner T-5's have their name stamped on them.
Old Oct 23, 2001 | 05:47 PM
Camaroman's Avatar
there is a tag under one of the tail stock bolts...from there the tag needs to be decoded
Hotrodboba400
Dec 10, 2019 07:07 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
